SamGreen
Jun 29, 2020Aspirant
Secure Network
While connected to the Orbi network, every website I try to go to and even on my cell phone, tells me it cannot connect do to the network not being secure. Whenever I disconnect from the Orbi network...
Jun 29, 2020Guru - Experienced User
So is Orbi on your home network do you have a differnt wifi system at home along with Orbi?
Do you have Armor or Disney Circle feature apps enabled on Orbi?
SamGreen
I already had my home network. I added Orbi because I couldn't get a stronge enough signal upstairs and I was told Orbi would solve this. However the Orbi is useless becaause I can't connect to any website because it says the connection is not secure. Therefore, I have to disconnect from Orbi every time and connect to my original network.
- FURRYe38Jun 29, 2020Guru - Experienced User
So please answer the following:
What Orbi model system do you have?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Do you have Armor or Disney Circle feature apps enabled on Orbi?
How is Orbi connected to your home system?
What is your home network system comprised of?
