SamGreen
Jun 29, 2020Aspirant
Secure Network
While connected to the Orbi network, every website I try to go to and even on my cell phone, tells me it cannot connect do to the network not being secure. Whenever I disconnect from the Orbi network...
NirmalM
Aug 12, 2020Aspirant
Hi Sam, I just picked up an Orbi with 2 satellites, RBR50v2. I struggled with the same problem for 4 hours before I gave up and removed the Orbi and replugged in my old Nighthawk, after which all devices worked fine.
Were you able to find the cause of the problem? or did you return your Orbi?
Would be great if you could let me know, thanks in advance.
SamGreen wrote:While connected to the Orbi network, every website I try to go to and even on my cell phone, tells me it cannot connect do to the network not being secure. Whenever I disconnect from the Orbi network and then connect to my network on my home router everything is fine. This has been happening from day 1. This makes the Orbi useless and will be returned asap if this is normal.
