nagendraprasath
Dec 16, 2019Aspirant
Security Concern - Guest network allows to access local resources
with "Allow guests to see each other and access my local network " turned OFF, netgear Router Orbi RBR50 is allowing device connected on Guest network to access devices connected to LAN. I've a NAS...
nagendraprasath
Dec 17, 2019Aspirant
Sure. Below is the firmware of router and satellites
Router RBR50 Orbi Router V2.3.5.30 Satellite RBS50 Orbi Satellite-1 V2.2.1.210 Satellite RBW30 Orbi Satellite-2 V2.3.5.6 Satellite RBW30 Orbi Satellite-3 V2.3.5.6
tucsontico
Dec 17, 2019Virtuoso
The RBS50 satellite should be the same firmware as the RBR50 router. You need to update the satellite from 2.2.1.210 to 2.3.5.30. After the update do a factory reset and reconfigure your system from scratch (not from a backup config file). I know it is a PITA but that's the best way to get rid of potential conflicting remnants of previous firmwares. That should clear up the guest network access issue.
- nagendraprasathDec 17, 2019Aspirant
RBS50 has been disconnected for the last 8 months. I'm no longer using this satellite. Disconnected it from RBR50 and Guest networks isolates access to local resources now. Appreciate your suggestion.
- CrimpOnDec 17, 2019Guru - Experienced User
nagendraprasath wrote:RBS50 has been disconnected for the last 8 months. I'm no longer using this satellite. Disconnected it from RBR50 and Guest networks isolates access to local resources now. Appreciate your suggestion.
Well, this is a new one. I am confused by the term "disconnected". The RBS50 has been powered off for 8 months, and "disconnecting" it from the RBR50 is what caused the Guest firewall to operate correctly?
