OrbiRocks
May 03, 2020Guide
Security Tab missing
I've notices since putting the router in AP mode, I can't see the security tab. Is this normal? Can I run Armor if the routers is in AP mode?
CrimpOn
May 03, 2020Guru - Experienced User
OrbiRocks wrote:I've notices since putting the router in AP mode, I can't see the security tab. Is this normal? Can I run Armor if the routers is in AP mode?
There are many things the Orbi no longer does when in Access Point mode, including Armor and Disney Circle. That's what "Access Point" is rather than "Router." Since most people are better off with only one router, they have to decide which "router" they want the most and put the other device into "Non-router" mode.
OrbiRocks
May 03, 2020Guide
I only have the Orbi connected to my internet modem through the WAN port. I had to put it in the AP mode to be able to get my direct tv box to connect.
- michaelkenwardMay 03, 2020Guru - Experienced User
OrbiRocks seems to have several things going on at the same time.
Connecting DirectTV - NETGEAR Communities
Nothing wrong with that, but it helps to join up the dots. I suspect that these issues are related.
- FURRYe38May 03, 2020Guru - Experienced User
Built in router here by chance? if so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeI would try option 1 first, if that can't be done, try option #2 if you want to use the Orbi in router mode.
OrbiRocks wrote:I only have the Orbi connected to my internet modem through the WAN port. I had to put it in the AP mode to be able to get my direct tv box to connect.
