OrbiRocks
May 02, 2020Guide
Security Tab missing
I've notices since putting the router in AP mode, I can't see the security tab. Is this normal? Can I run Armor if the routers is in AP mode?
OrbiRocks
May 02, 2020Guide
I only have the Orbi connected to my internet modem through the WAN port. I had to put it in the AP mode to be able to get my direct tv box to connect.
michaelkenward
May 03, 2020Guru - Experienced User
OrbiRocks seems to have several things going on at the same time.
Connecting DirectTV - NETGEAR Communities
Nothing wrong with that, but it helps to join up the dots. I suspect that these issues are related.
