ryanjohn04
Aug 01, 2017Guide
See which devices using Router WiFi (not Satellite)
I understand how to see which devices are connected to the Satellites (take the IP address from the main Attached Devices page and enter into a browser). How can I see which devices are connected di...
- Aug 03, 2017
Hello ryanjohn04
Process of elimination would be the way to figure it out whatever is not connected to the satellite will be whats connected to the router. Sorry this isnt a very clear way to do it.
DarrenM
DarrenM
Aug 03, 2017Sr. NETGEAR Moderator
Hello ryanjohn04
DarrenM
ryanjohn04
Aug 13, 2017Guide
Thanks Darren- would think its a pretty easy thing to add to the connected devices, a column which shows whether its a satelitte (and which one) or the main router. But appreciate the answer and makes sense. Thank you
