fanofai
Apr 18, 2021Guide
Seeking feedback on Mesh network design
Hi,
We are evaluating how to design a mesh network for our apartment community using the Orbi RBK53 router along with 2-RBS50Y outdoor extenders. The main idea is to support security cameras (& nothing else!). Based on indoor trial runs, the camera is able to upload videos to the cloud using a 4Mbps wireless connection. The next step is to run a pilot effort and set the camera outdoors and hence the need for a mesh WiFi.
In the linked proposal below,
- Router is placed at the square box labeled R, and the Extender is labeled E.
- wireless security cameras (on 2.4G network) will be placed at the boxes labeled C, and the blue boxes in the figure.
https://drive.google.com/file/d/1ZVttGAjXdqNgSjbM-Li5ONjV-7Z2EWeo/view?usp=sharing
(also attached if the link doesn't work)
Any feedback on the following questions would be greatly helpful. Thanks in advance!
- For the pilot effort (page 1of link below), straight-line distance from the router (labeled R) to the extender (labeled E) is 40meters or ~120 feet, and has no obstructions. Based on online reviews (Reference link 1) the Router-Extender Combo should be able to handle this distance comfortably. Any comments?
- For the final layout (on page 2), the router is going to be moved to the Clubhouse in the community. The distance between the router and extender now exceeds well over 100 meters not to mention there are building in-between the two. Hence, the plan is to have an extender in the middle at ~50 meters.
- Are Orbi RBK53 router & 2-RBS50Y outdoor extenders the right products to be used? If other products are more suitable, can you please suggest those?
- Since this is the first time I am setting up a mesh network, any basic pointers to keep in mind?
Thanks,
fanofai
References:
1. Reviewer claims to get nearly 100% signal strength at extender which is placed at a straight line distance of 28 meters from the router
All this to monitor 1 out of 4 dumpsters?
(and from pretty far away)
I would be tempted to look at an LTE solution, such as this one:https://reolink.com/us/product/reolink-go/
Those distances will be a struggle for WiFi.
You might look at Ubiquiti, rather than a mesh system intended to support a single house. I believe they have products specifically designed for things like mounting security cameras.
- fanofaiGuide
Thanks CrimpOn.
"All this to monitor 1 out of 4 dumpsters?"
Nope! The plan is to have 1-camera per dumpster (see attached) to monitor illegal dumping & dumpster abuse, as well as 1-camera for each of the 2 entrances. In total 6-cameras, and possibly a few more if the need arises.
The LTE solution wouldn't work for us due to the high traffic. The existing camera uploads ~2GB of data every day!
"You might look at Ubiquiti, rather than a mesh system intended to support a single house. "
Thanks..I shall check that too.
-Sharath
Orbi 50 series is for home class configurations. You might try Orbi pro. There meant for low end business. However distance will still be a problem along with other noise and conditions.
For cameras, you should look into wired camera solutions instead.
Good Luck.
