MrTaz40
Jul 10, 2018Aspirant
Seemingly random loss of internet on random devices
Hi All,
I have an RBR40 Orbi Router with 2 RBS40 Orbi satellites (for some reason I can not select RBR40 in the list of models on the boards here).
Since I put the units in place over a year ...
Jul 10, 2018Guru - Experienced User
What FW version are you using the the router and Satellite(s)?
What Mfr and model# ISP modem is the Orbi connected too?
Any wifi neighbors nearby? If so, how many?
Try using manual channel 1, 6 or 11 on 2.4Ghz.
Disable MIMO, Daisy Chain and Fast Roaming.
Ensure distance between the router and satellites starts at about 30 feet minimum. Any closer and could be problems, same with being too far. Also bulding materials can impact wireless.
MrTaz40
Jul 11, 2018Aspirant
Thanks for the reply FURRYe38.
I am running the latest firmware: V2.1.4.16. The problem is that this has been happening since I have owned the units, its not new, I have used many different firmwares and on some it has been worse than on others.
I have attempted manual channels and have attempted disabling MIMO, Daisy Chain and Fast Roaming and none of them seem to change the situation.
The units are placed signifcantly apart. One is on the 3rd floor, one is in the basement and one is in the pool house. Each are more than 30 feet away from any other. The house was built in 1990. It has some interesting materials, including steel struts in each floor and interior metal beams between rooms. With previous single routers, i could almost cover the whole house and did not have any problems with devices loosing internet connectivity but maintaining wifi connectivity. My network has grown significantly since I last used a single device for my wifi needs.
I have an older MOTOROLA SB5120 Surfboard modem, it hasn't been upgraded in years, and I will probably try to upgrade that later today. Is there a test I can perform to see if it is the modem without buying a new one? A way to monitor the traffic through the router to see if the modem is dropping the connection before it sends it on to my provider? The modem is my modem, but ofcourse it is connected to Xfinity, so I am slightly limited to what they let me have access to on it.
