a-brittis
May 12, 2020Star
Selecting higher channels via Telnet
Referencing closed post by dan801 who asked the question: I understand the GUI only allows lower 5ghz channels. I also believe the higher channels 149 etc is used as a backhaul channel. Has any...
May 26, 2020Guru - Experienced User
Does this persist passed a reboot?
a-brittis wrote:Referencing closed post by dan801 who asked the question:
I understand the GUI only allows lower 5ghz channels. I also believe the higher channels 149 etc is used as a backhaul channel. Has anyone figured out a way to force a higher channel via Telnet similar to seperating the SSID. My apartment is so congested with 36-48 channels its not funny.
Original Post: https://community.netgear.com/t5/Orbi/Selecting-higher-channels-via-Telnet/td-p/1685965
I was poking around with the config, and found that this may work. I've tested it for a short while, but then reverted back to channel 48. It would be interesting if others test this and report back here.
I did notice that there was some code in the wifison-monitor.sh script that contains some logic regarding DFS channels. This is the same script that monitors the ssids of 2.4 and 5 GHz channels and changes them back to be the same. You may need to disable the monitor for this to work as well. Also, I don't know if the DLS channels work well with the Orbi or not. Basically, this is untested. All I can verify is that it does actually changes the Orbi router to use the new channel. Try at your own risk and post your stories back here. You might want to make sure you can still access via 2.4 Ghz or ethernet in the case that the 5Ghz channel breaks.
// Enable telnet access on your router
http://192.168.1.1/debug.htm
check the box to enable telnet
// telnet to your router
telnet 192.168.1.1
// these commands will show your current 5Ghz channel
config get wla_hidden_channelconfig get wla_channel
// set new channel
config set wla_hidden_channel=64config set wla_channel=64
// I'm not sure if the monitor should be disabled or not. To disable the monitor, use the following command
config set wifison-monitor_stop=1
// commit changes
config commit
// reboot
reboot
a-brittis
Jun 22, 2020Star
It persisted after the first reboot. I didn't test subsequent reboots. I'm currently running my Orbi on one of the supported channels via the web UI, since I also have a NightHawk 4x router that supports the higher channels. I'm inviting users here to post the success (or lack of success) stories with the change.
FURRYe38 wrote:Does this persist passed a reboot?
- FURRYe38Jun 23, 2020Guru - Experienced User
Thanks for letting us know.
