a-brittis
May 12, 2020Star
Selecting higher channels via Telnet
Referencing closed post by dan801 who asked the question: I understand the GUI only allows lower 5ghz channels. I also believe the higher channels 149 etc is used as a backhaul channel. Has any...
a-brittis
Jun 22, 2020Star
It persisted after the first reboot. I didn't test subsequent reboots. I'm currently running my Orbi on one of the supported channels via the web UI, since I also have a NightHawk 4x router that supports the higher channels. I'm inviting users here to post the success (or lack of success) stories with the change.
FURRYe38 wrote:Does this persist passed a reboot?
Jun 23, 2020Guru - Experienced User
Thanks for letting us know.
