pdolmsted
Mar 16, 2021Tutor
Selectively shut out of wifi system
I have a very strange problem. RBK43S system with router and two satellites. Modem: Netgear CM1000 Internet: Xfinity/Comcast 1. I needed to reboot the router a few times. 2. Thus, final...
Mar 16, 2021Guru - Experienced User
What is the distance between the router and satellite(s)?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- FURRYe38Mar 16, 2021Guru - Experienced User
Opps sorry I saw your modem brand and model. :smileyembarrassed:
- pdolmstedMar 16, 2021Tutor
Info already provided: Netgear CM1000 [not from the ISP]
2500
What is the distance between the router and satellite(s)?around 30 feet, but this isn't the issue. It doesnt' work for me even when hard-wired into the router. Neither my wife or I are in range of or using the satellites.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...Has a factory reset and setup from scratch been performed since last FW update?
There is no recommendation to do this from Netgear. I don't want to do this but will try it if good reasons given. This can't explain the selective nature of shutting one person out, can it?
Yes. A reset would be needed to clear out any odd problems as a troubleshooting step.
OK, I'll try that once my wife has some down time. Very very strange.
Then, assuming that works, I'll re-upgrade my firmware to the new version, and hopefully all will be OK.
