ryanjohn04's avatar
Aug 28, 2017
Self-Assigned IP Address
On both my iPhone and MacBook I get a No Internet Connection error.  Most of my Orbi settings are on the defaults.  Most of the time when it happens it will eventually start working on its own afte a...
  • ryanjohn04's avatar
    ryanjohn04
    Sep 11, 2017
    Figured out my problem here, the issue was having a 4th satelitte.  As soon as I removed that one everything worked fine.  Was able to recreate the issue if I added the 4th satelitte again.  So I guess a 4th satelitte is indeed a bad idea currently.
