ryanjohn04
Aug 28, 2017Guide
Self-Assigned IP Address
On both my iPhone and MacBook I get a No Internet Connection error. Most of my Orbi settings are on the defaults. Most of the time when it happens it will eventually start working on its own afte a...
- Sep 11, 2017
Figured out my problem here, the issue was having a 4th satelitte. As soon as I removed that one everything worked fine. Was able to recreate the issue if I added the 4th satelitte again. So I guess a 4th satelitte is indeed a bad idea currently.
DarrenM
Aug 29, 2017Sr. NETGEAR Moderator
Hello ryanjohn04
What modem is orbi hooked up to does it have a router on it?
DarrenM
ryanjohn04
Sep 11, 2017Guide
