alanbc's avatar
alanbc
Star
Apr 22, 2023
Separate 2.4 GHz and 5 GHz on Orbi 50 (again)
I have WiFi cameras that require a connection to a 2.4GHz network.  (Most do, near as I can tell).  They also require the tablet/phone to be on the same network AND also the same speed network.   A...
  • alanbc's avatar
    alanbc
    Apr 24, 2023
    FURRYe38;
    Thanks for the reply!  As I mentioned in a previous post, your suggestion is how I eventually got the camera up.
    But my original post was about the problem in general .. not being able to rename a network or disable a network .. with the camera config problem being just one example of why I wanted to.  There's other times when this would be handy.
    I was kinda wondering if there was an undocumented web page in the router that allowed any extra configuration, in the same way that
      http://router.ip.address/debug.htm
    offers additional debug info.
