Confused147
Feb 11, 2022Aspirant
Separate 2.4 ghz from 5.0ghz
I need to rename the 2.4Ghz SSID so it is different to the 5 Ghz SSID. I can't do this via Telnet as NetGear have disabled this. There are MANY devices from manufacturers such as Jura, Whirlpool, J...
- Feb 11, 2022
i haven't had issues in quite a while with IoT devices. They should work if you're connected to 5ghz but if they don't its because of poor coding on the device makers part.
What I used to do when mesh first came out and it was an issue?
I either used an old router or a hot spot. I'd shut off my primary router and name the hotspot name the same as my router. Setup the Iot device, turn off the hotspot, and boot up the mesh router. the devices always connected. Again, I haven't had to do this in years.
Feb 11, 2022Guru - Experienced User
Confused147
As it happens, I had come to the same conclusion and was part way through setting up an old router when I read this. It solved my problem. Thanks
