sclawrenc
Sep 30, 2019Apprentice
Separate WiFi 2.4 and 5ghz bands
I am no longer able to separate my WiFi bands on the most recent Orbi firmware versions. It worked for over a year fine, but after updating firmware they are no longer separate. I have tried the Te...
sclawrenc
That’s too bad. Can they not allow that in the settings for the many many users that want to separate them?
I purchased the Orbi because I knew of the separate 2.4 and 5ghz telnet solution. I used it this way perfectly for about a year. It no longer works and now I’m not nearly as happy with my Orbi.
Specifically, my 4K media devices will connect to the 2.5 band now instead of the 5 band which causes buffering and downgraded video. I never had this problem when I could separate the bands and decide what band my devices connected to.
Sep 30, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
