sclawrenc
Sep 30, 2019Apprentice
Separate WiFi 2.4 and 5ghz bands
I am no longer able to separate my WiFi bands on the most recent Orbi firmware versions. It worked for over a year fine, but after updating firmware they are no longer separate. I have tried the Te...
notepro
Dec 27, 2019Tutor
I am also running the v2.3.5.30 firmware on the RBR40 Orbi setup and have tried to separate the 2.4 and 5 bands multiple times with no success. When I telnet in and check the SSID names, they are different, even after a reboot. But it is only broadcasting the 2.4 SSID and devices on my network are connecting to that SSID at the 5ghz speed. It doesn't make any sense. Any ideas?
SW_
Dec 27, 2019Prodigy
notepro wrote:I am also running the v2.3.5.30 firmware on the RBR40 Orbi setup and have tried to separate the 2.4 and 5 bands multiple times with no success. When I telnet in and check the SSID names, they are different, even after a reboot. But it is only broadcasting the 2.4 SSID and devices on my network are connecting to that SSID at the 5ghz speed. It doesn't make any sense. Any ideas?
Yeah - You're not alone seeing this problem with these later firmware iterations. It seems that NG has already begun to lockdown custom configs. I also have a need for separate WiFi/SSIDs and my solution is Guest Network, which still works with the latest FW v2.5.1.8 on RBK53. If you must have separate WiFi/SSIDs, you can look into these options and see which one will work for you.
- Revert to an older firmware version prior to lockdown
- Take advantage and enable separate WiFi/SSIDs on Guest Network
Check out this post on how to separate WiFi for 2.4GHz and 5GHz bands on Guest Network.
Good Luck!
