sclawrenc
Sep 30, 2019Apprentice
Separate WiFi 2.4 and 5ghz bands
I am no longer able to separate my WiFi bands on the most recent Orbi firmware versions. It worked for over a year fine, but after updating firmware they are no longer separate. I have tried the Te...
notepro
Dec 28, 2019Tutor
It might be clearer to me once I understand the naming system. So does wlg1_ssid refer to Satellite 1 on the Guest Network? Does wla1_ssid refer Satellite 1 on the Main wifi network? If so, what is the designation for Satellite 2 on both the Guest and Main networks? Sorry for my confusion.
SW_
Dec 28, 2019Prodigy
notepro wrote:It might be clearer to me once I understand the naming system. So does wlg1_ssid refer to Satellite 1 on the Guest Network? Does wla1_ssid refer Satellite 1 on the Main wifi network? If so, what is the designation for Satellite 2 on both the Guest and Main networks? Sorry for my confusion.
These two variables are used by Guest network only. wla1_ssid is just a variable to store Guest SSID name for 5GHz, similarly wlg1_ssid stores Guest SSID name for 2.4GHz. Each of these 2 variables will tell Orbi/Satellite what Guest SSID to broadcast. By default, both stores the same Guest SSID for both bands. The Main WiFi network uses a different set of variables to store its SSID i.e., wla_ssid and wl_ssid.
Think of it as two different WiFi networks. Whatever changes we make to Guest SSID (wla1_ssid/wlg1_ssid) won't affect the Main nerwork SSID (wla_ssid/wl_ssid) at all.
For examples:
- To force Satellite-1 broadcasting unique 5GHz Guest SSID name, telnet into Satellite-1, and set its wla1_ssid="Satellite-1-5GHz"
- To force Satellite-2 broadcasting a different Guest SSID from Satellite-1, telnet into Satellite-2, and set its wla1_ssid="Satellite-2-5GHz"
- To force Orbi broadcasting a different Guest SSID, telnet into Orbi, and set its wla1_ssid="Orbi-5GHz"
Hope this helps!
- noteproDec 28, 2019Tutor
Wow, thank you for that. So much clearer and I appreciate your help.
