sclawrenc
Sep 30, 2019Apprentice
Separate WiFi 2.4 and 5ghz bands
I am no longer able to separate my WiFi bands on the most recent Orbi firmware versions. It worked for over a year fine, but after updating firmware they are no longer separate. I have tried the Te...
Feb 17, 2020Guru - Experienced User
Anytime. Some people may not read the entire thread so just informing them.
Enjoy. :smileywink:
OrbiPhilip
Feb 24, 2020Luminary
FURRYe38 wrote:Enjoy. :smileywink:
Enjoy? Are you leaving the forum?
- th3w01fFeb 24, 2020ApprenticeEnjoyment was never a supported feature and was never well documented. Any enjoyment you’ve gotten has been a byproduct and is now on the bug list to be removed with a future update that breaks satellite to router communications and requires a manual update of everything.
The manual update wasn’t required. It was added to the supportability list after it was shown to detract from enjoyment.
