jdb1970
Mar 09, 2020Tutor
Separating bands on my RBR20
I'm having issues with my SimpliSafe security camera connecting/staying connected to my wifi extender. Simplisafe is telling me that the camera must have a dedicated 2.4 ghz line, it will not work o...
Mar 09, 2020Guru - Experienced User
First try this:
Disable the 5Ghz SSID broadcast on the RBR. Then get your setup device and installation device connected on the Orbi:
jdb1970 wrote:I'm having issues with my SimpliSafe security camera connecting/staying connected to my wifi extender. Simplisafe is telling me that the camera must have a dedicated 2.4 ghz line, it will not work on 5 ghz. If they are right I need to separate my channels and dedicate this to the 2.4 line. I've tried a telnet method to make this change but the change did not hold and it immediately went back to the single SSID. How canI make this a permanent change? Do I need to scrap this system and go to another system?
