masterof1's avatar
masterof1
serial already registered rbk50 bought on eBay
need help registering the rbk50 I just bought on ebay..
some one I can contact
  • michaelkenward's avatar
    michaelkenward
    You have a couple of options, try to find a local contact number (it may be well hidden) or send a private message to one of the Netgear moderators here.
    If you are really lucky, someone like Christian_R, ChristineT or DexterJB will step in.
    • masterof1's avatar
      masterof1
      thanks...lets hope I can get some help from the mods...really sad that I just got it and can not get it to work..
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi masterof1
        Please check your inbox.
        Blanca
        Community Team
