Mageezer
Jun 15, 2021Aspirant
Serial Number not recognized orbi
I have to do a factory reset on my router because I cannot login to orbilogin.net or 192.168.1.1. When I select the option to login using serial number it says the serial number on the bottom of my ro...
PatmanGear
Sep 30, 2023Initiate
Unfortunately, the problem the user is having is not understood by the person replying. When you can't remember the password, try to login 3 time unsuccessfully, you are prompted to enter the serial number of the router to help log in. However, when typing in the serial number of the bottom of the router, the reply is that the serial number doesn't match the router. The user is not the only one having this problem.
- CrimpOnOct 01, 2023Guru - Experienced User
This is a valid observation (although a bit late to be helpful).
It is difficult to speculate what could cause the router not to accept the serial number printed on the product label. Whatever the cause is, I am unaware of any method to gain access to the router web interface except doing a Factory Reset.
