rzippelius
Jan 26, 2021Aspirant
Serious connectivity bug with RBR20-V2.6.1.38 firmware
I recently upgraded my RBR20 to the RBR20-V2.6.1.38 firmware (from RBR20-V2.5.1.16). After the upgrade I was no longer able to connect to my NAS, which is connected via ethernet directly to the route...
rzippelius
Jan 28, 2021Aspirant
I did a manual upgrade using the latest RBR20 and RBS20 FW from the Netgear site. I did the upgrade because my understanding is that the version I was using has some security issues that have been fixed in the latest version. Pick your poison.
Jan 28, 2021Guru - Experienced User
Did you try a factory reset and setup after you updated the FW?
rzippelius wrote:I did a manual upgrade using the latest RBR20 and RBS20 FW from the Netgear site. I did the upgrade because my understanding is that the version I was using has some security issues that have been fixed in the latest version. Pick your poison.
