rzippelius
Jan 26, 2021Aspirant
Serious connectivity bug with RBR20-V2.6.1.38 firmware
I recently upgraded my RBR20 to the RBR20-V2.6.1.38 firmware (from RBR20-V2.5.1.16). After the upgrade I was no longer able to connect to my NAS, which is connected via ethernet directly to the route...
rzippelius
Jan 28, 2021Aspirant
I did the upgrade in response to an email sent out on 12/27/20 by NETGEAR Security <security@e.netgear.com> titled "Important Security Firmware Update from NETGEAR" recommending to upgrade the firmware of the RBR20 The email said "We've Enhanced Your Product's Security. Please Update to the Latest Firmware.". Usually it is very advisable to follow such recommendations, if they come directly from the vendor.
I did not do a factory reset after the upgrade. Usually that is not requird unless explicitly stated in the upgrade instructions.
Jan 28, 2021Guru - Experienced User
A reset maybe need to ensure the FW and new configuration in place. Some newer FW versions may not work well with older configurations. Up to you though.
rzippelius wrote:I did the upgrade in response to an email sent out on 12/27/20 by NETGEAR Security <security@e.netgear.com> titled "Important Security Firmware Update from NETGEAR" recommending to upgrade the firmware of the RBR20 The email said "We've Enhanced Your Product's Security. Please Update to the Latest Firmware.". Usually it is very advisable to follow such recommendations, if they come directly from the vendor.
- rzippeliusJan 28, 2021Aspirant
I will try the factory reset. Thank you for the recommendation.
- vajimJan 28, 2021Master
rzippelius wrote:I will try the factory reset. Thank you for the recommendation.
Yes. Let us know if it works
thanks
- rzippeliusFeb 07, 2021Aspirant
Unfortunately, the factory reset did not make a difference. Some network devices still don't show up.
