benn600
Jun 14, 2017Apprentice
Serious Satellite Connectivity Bug
This is not intermittent or difficult to reproduce. I consistently am unable to connect to devices on my Orbi network. I have seen this problem 15-20 times over about 2 weeks and I have power cycle...
benn600
Jun 15, 2017Apprentice
I will try decreasing the power. I just don't think it's a connectivity problem, but more like a "firewall" or software breakage in the virtualized network connected via the backhaul. It's not that packets drop or bars go down, it's that a whole wing of my network vanishes.
Sat1 -> Router -> Sat2
When I'm on a satellite, every device on the other satellite is invisible about 40% of the time. That whole satellite is gone.
I have everything plugged into a satellite that I can. This is the whole purpose of Orbi, to get a dedicated and separate backhaul. All units in my complex are townhouses so the density is a bit lower than small apartments, by at least half or less. I have every radio turned off that I can and plugged the devices into a port so Orbi can do what it was designed to do. Handle as much traffic as possible on the dedicated wireless backhaul.
Reducing wireless transmit power I can see as a solution because my devices might be hopping too much. But again, I don't even think that's the problem. I never have trouble getting internet, or connecting to devices on the router. It's only the double hops on the backhaul. This seems like a software block or error and something reboots internally periodically that resets it and it works. Interestingly enough it always works great after a power cycle. It would be great if I could turn a satellite into ONLY a backhaul receiver that does not rebroadcast my wifi, but simply gives me bridged ports. I have 3 main areas where devices live that can be hard wired but no Ethernet. If I was willing to cut the walls I wouldn't have gotten Orbi. This is the primary selling point on the box as well as logically.
st_shaw
Jun 15, 2017Master
Sounds like you've done a lot already. You might be able to test your theory about the inter-sat communications by telnetting into a sat and pinging the other sat when you have the problem happening.
The only other thing I can say is it's quite important to try moving the Orbis relative to each other and relative to your other WiFi devices. I've seen it cause problems with my setup with the Orbi apparently saturating another device's radio when they were too close. Also, RF waves bounce around inside and it's possible one satellite is in a bad spot for the backhaul. If you put a switch between your devices and the sat, and put the sat on a long ethernet cable, you can move the sat around quite a bit.
- benn600Jun 15, 2017Apprentice
While I'm connected to an Orbi node, I have a rock solid connection to that. When I'm even remotely close to my Kitchen satellite, my Living Room satellite devices are rock-solid unavailable. As soon as I move even somewhat close to the Living Room satellite, my iPhone hops over and suddenly everything is visible. I'm running Fing regularly and lots of devices are grayed out (unreachable) and it quickly tells me which node I'm on and which node is unavailable. But sometimes it works fine without a problem.
