benn600
Jun 14, 2017Apprentice
Serious Satellite Connectivity Bug
This is not intermittent or difficult to reproduce. I consistently am unable to connect to devices on my Orbi network. I have seen this problem 15-20 times over about 2 weeks and I have power cycle...
Stkasm
Jul 08, 2017Apprentice
benn600 you're right. It has nothing to do with your signal. what you're describing looks like a bridge misconfiguration or a routing problem between tunnels on Orbi router's side.i'll do a quick test with my system when I'm back home - early next week.i have two satellites. My orbi system is in AP mode and I also have Sonos using 2.4G Orbi network. Sonos works just fine but it's pretty complex in the way it uses the network. Out of about 20 devices connected to the network backbone Sonos is the only type of workload that wants to communicate between the nodes and uses only Orbi.everything else is from Orbi to WAN router or from Orbi to Ethernet connected devices via central switch. Anyway, what you're describing should be super easy to reproduce
