benn600
Jun 15, 2017Apprentice
Serious Satellite Connectivity Bug
This is not intermittent or difficult to reproduce. I consistently am unable to connect to devices on my Orbi network. I have seen this problem 15-20 times over about 2 weeks and I have power cycle...
benn600
Jul 15, 2017Apprentice
No luck!
I received the RMA replacement and installed it in my kitchen. I reset both my living room and kitchen satellites and paired them both. Every single time reproducible steps:
1. Stand near kitchen and view kitchen camera or connect to kitchen speaker.
2. Walk upstairs and stand near the router, both devices are *gone* and I cannot connect to either device, or the satellite itself.
This is definitely a serious problem. While I'm connected to the router on my iPhone (wirelessly) I cannot connect to the other satellite.
I have seen this problem go the other direction where I cannot ping the living room satellite. It almost seems like one direction is damaged while the other is okay. Then it flips back. One direction works while the other doesn't. As if the back-haul can only have one active connection to a satellite at a time.
st_shaw
Jul 15, 2017Master
You received your RMA replacement what? Router or satellite? It's not clear at all, but it sounded like a satellite problem to me.
- benn600Jul 15, 2017Apprentice
I received a new satellite, which I don't necessarily agree is the problem. I'm still trying different things.
- st_shawJul 15, 2017Master
Your probelm is strange. You mentioned 100 devices with DHCP reservations and you also mentioned a limit of 64 DHCP reservations. Those don't add up. Maybe there's an IP conflict somewhere.
Did you try letting Orbi handle the IPs with no manual reservations?
Did you try using Orbi in AP mode with another router?
I meant 100 for dramatic effect. I have around 80 or so and yes, I hit the limit as my script was running to add them all. I just now reset my Orbi to 100% factory settings and am not putting anything in other than my WiFi password, and I even made a new one so nothing will connect except devices that I want to connect.
Going to test some more things.
