otoko
Dec 25, 2017Tutor
server access via wifi orbi
hi, i installed my orbi wifi network creating a personnal wifi which works perfectly well. How do i manage to connect to my synology server (lan plugged to my modem) via the "orbi wifi?? i thoug...
aaz
Dec 25, 2017Virtuoso
Please clarify - Do you have the Synology plugged into your ISP router? And your Orbi router is also plugged into the ISP Router.
If so you have two seperate networks and it cannot work.
You need to plug all your wired devices directly into the Orbi and it's satellites - then your wireless devices can connect to those.
Also the Orbi router's WAN port has to plug into the ISP routers internet port and you have to either ask the ISP to set their router to bridged mode or do that yourself if you can - so that the ISP can give your Orbi router and internet address (otherwise your orbi is only running on an internal network IP and things will not work as you expect with double NAT.)
- otokoDec 26, 2017TutorHi,
I have the Synology and the orbi plugged into to ISP router.
I thought that way by connecting to the « orbi WiFi » on my Mac book Pro would allow me to see and access my synology through the finder.
I used to access it via WiFi before Orbi. I used a netgear repeater that had a different WiFi name than the ISP WiFi.
