Tosaf
Dec 20, 2021Aspirant
Server certificate can not be trusted - orbi mesh
Hi all, I never had issues with my orbi rbk53 mesh. I have a router and 1 satellite. The issues started after activated the trial of parental controls. Played with it, blocked my lg oled tv. Sinc...
- Dec 20, 2021I just setup orbi as AP.
No more issues with that.
I know that it’s not a great solution, but until netgear will learn how to write a software, this will do it.
Thanx, for everyone help.
Dec 20, 2021Guru - Experienced User
Factory reset the RBR and setup from scratch. Be sure to not enable Circle or Armor after walking thru the setup wizard.
You might reset the TV as well.
Tosaf
I know factory reset will fix it for sure, but resetting the tv is a problem finding the Plex server, Netflix, amazon prime, Apple TV, and more passwords…
That should never happen in the first place..
- CrimpOnDec 20, 2021Guru - Experienced User
Sound like a good plan. Reset the Orbi, but do not touch the TV unless absolutely necessary.
- TosafDec 20, 2021AspirantI just setup orbi as AP.
