Tosaf
Dec 20, 2021Aspirant
Server certificate can not be trusted - orbi mesh
Hi all, I never had issues with my orbi rbk53 mesh. I have a router and 1 satellite. The issues started after activated the trial of parental controls. Played with it, blocked my lg oled tv. Sinc...
- Dec 20, 2021I just setup orbi as AP.
No more issues with that.
I know that it’s not a great solution, but until netgear will learn how to write a software, this will do it.
Thanx, for everyone help.
Tosaf
I know factory reset will fix it for sure, but resetting the tv is a problem finding the Plex server, Netflix, amazon prime, Apple TV, and more passwords…
That should never happen in the first place..
CrimpOn
Dec 20, 2021Guru - Experienced User
Sound like a good plan. Reset the Orbi, but do not touch the TV unless absolutely necessary.
- TosafDec 20, 2021AspirantI just setup orbi as AP.
