kal8v9
Feb 21, 2021Aspirant
Set RSR10 up
Few questions I am setting up my Orbi Mesh System. 1. I am using a Cradlepoint IRB600 as my router/modem. Where should I hook the Orbi mesh up to the WAN or the LAN port? 2. Also I want to conne...
Feb 23, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
The Orbi RBR always uses the WAN port when in router or AP mode.
