MelsPartner
Jan 12, 2021Initiate
Set up 2 routers 1 modem
How to set up 2 routers with one modem Ok so I know nothing. I've got a modem/router supplied by my ISP. This is in an outhouse building (why the designed it like that i don't know From this...
- Jan 12, 2021
Firstly, you should disable the router portion of your cable modem. Otherwise you'll have two "NAT"'s, which can cause complications.
How-to-fix-issues-with-Double-NAT
One can use 2 routers but it is unneccessarily complicated. There is a brief description at
Option 2 is the way to go, with using the 2nd Orbi as an access point (in other words, disabling its router functions). A better way (that will allow roaming between the different parts of your house) is to use a single Orbi router and as many Orbi satellite as needed to provide a single WiFi name (SSID) throughout your house.
Jan 12, 2021Guru - Experienced User
You could have two routers connected to the modem thought it would not be a ideal configuration.
From this place in one direction I have a wire going to the main home and a router there.
In the opposite direction we have now built an office in the garden for me to work from and I have a router there.
My question is how should I set this up correctly.
Do I need to stop the router combined modem from being a router?
Can I continue to have both routers connected direct to the modem?
Help because what is happening at the moment isn't working. We are getting alot of Internet dropping.
One router is a rbk30 the other rbk50
Thanks in advance.
- vajimJan 12, 2021Master
Message 3 pretty much sums it up.
