Godders1975
Aug 20, 2021Initiate
Set up issue - NBN FTTP / Orbi RBR50 - Australia
Greetings! (context) Have been connected to FTTC for a whoile now using an Archer C60 which has been good with no issues at all, however just in the process of moving house to a place with FTTP ...
- Aug 22, 2021Problem resolved.
Took them to work to check, basically appears the set up didn't complete properly. Firmware updated and all appears to be good.đ
Aug 21, 2021Guru - Experienced User
Have you tried setting it up using a pc instead of the app? I'm not a huge fan of the app process.
What ONT do you have?
what firmware is on it? (might have updated and factory reset itself)
Godders1975
Aug 22, 2021Initiate
Problem resolved.
