Godders1975
Aug 20, 2021Initiate
Set up issue - NBN FTTP / Orbi RBR50 - Australia
Greetings! (context) Have been connected to FTTC for a whoile now using an Archer C60 which has been good with no issues at all, however just in the process of moving house to a place with FTTP ...
- Aug 22, 2021Problem resolved.
Took them to work to check, basically appears the set up didn't complete properly. Firmware updated and all appears to be good.đ
Godders1975
Aug 22, 2021Initiate
Problem resolved.
Aug 22, 2021Guru - Experienced User
glad to hear you got it fixed. If you mark the solution as solved, it might help the next person with that issue
