HarrySanJose's avatar
HarrySanJose
Follower
Dec 04, 2019
Setting a new password on an Orbi50
I just set up a new Orbi50 with 2 satellites.  Everything works fine.  Now I want to set a new access password for the Orbi50.  The User Manual says to logon to orbilogon.com.  When I enter that I ge...
  • CrimpOn's avatar
    Dec 04, 2019
    When you are attached to the Orbi, and it is in router mode (the default), it should resolve the name "orbilogin.com" to the IP address of the Orbi router and bring up the Orbi web interface.  If this is not happening, then you need to enter the IP address of the Orbi.  It is usually 192.168.1.1.  On most devices, if you look at the internet parameters, it will be the IP address of the "gateway"
