MargeE
Oct 12, 2018Aspirant
Setting up AC3000 for sprawling ranch house
I am looking to setup a mesh network in my daughter’s long sprawling ranch house. The square footage is 2700 ft, 5 bedrooms, plus 5 other rooms. The layout leans more toward a long rectangle than a...
Oct 12, 2018Guru - Experienced User
2700sq ft is a bit small for a 3 pack. I would try a base router and 1 satellite. I have a 5000sq ft home two level multiple rooms and use the base router upstairs at one end of the house and the satellite at the other end. about 40 feet in between. 30 feet is recommended between base router and satellite to begin with depending upon building materials. wood and dry wall doesn't present much of a problem. Older homes or building of concrete, this can pose a problem for wifi signal penetration.
Have had zero issues with wired back haul. Have there network switches in between my router and satellite.
- MargeEOct 12, 2018Aspirant
Is the recommendation for 30 ft between so the wireless coverage doesn't overlap? In other words, what happens if the distance is less than 30 ft.?
- FURRYe38Oct 12, 2018Guru - Experienced User
yes, you don't want too much over lap. So farther is best from the router. The router can cover up to around 2000sq ft alone. 30 feet seem to be a starting point for Orbi systems.
- Retired_MemberOct 12, 2018
The size of a house is NOT a factor in the WIFI world, unless you're trying to push the signal from one end to the other. It's range NOT house size.
The router will be in the middle of the house. Then I have about 45 ft to the first satellite going one way, and 40 ft to the second satellite going the opposite way. Very long, skinny space. Are there any down-sides to using the RBR50 router and two RBS50 satellites? Would using one of the wall plug satellite models in the location that does not need ethernet connections make better sense?
If your placing the router in the middle and have a satellite on opposing sides, that distance, you'll be fine. Just wanted to make sure you don't get too much over lap between them.
Any other wifi nieghbors near by?
A plug in would work as well if theres not much need for internet access at a remote location. Of course, the satellite you get in the box will work as well. The 3 pack should cover your household nicely in that configuration.
