jrmurf
Jan 17, 2017Initiate
setting up an ORBI with a AT&T U-Verse Pace 5268AC
I have had my ORBI set up for a while but we are just noticing it is interferring with our download speeds I have it wired to my Pace 5268AC, which I disabled the Wi-Fi and put the ORBI in AP Mode ...
RonV42
Jan 17, 2017Luminary
If I am reading your post properly you plug the orbi in the AT&T Uverse 5268ac the speed drops and is unpredictable? I asssume you are using the "WAN" port on the Orbi and plugging it into port 1-4 on the 5268ac. Have you tried a different cable or a differnt port on the 5268ac? Usually pluggin a device into the uverse gateway shouldn't effect the speed of the device or perfomrnace unless there is a hardware issue such as cable or device.
What services do you subscribe to with U-verse in addtional to internet access? How are you measureing performance?
