jrmurf
Jan 17, 2017Initiate
setting up an ORBI with a AT&T U-Verse Pace 5268AC
I have had my ORBI set up for a while but we are just noticing it is interferring with our download speeds I have it wired to my Pace 5268AC, which I disabled the Wi-Fi and put the ORBI in AP Mode ...
juniormint88
Jan 17, 2017Tutor
I turned off WiFi on the Pace modem and attached the Orbi to one of the ports. Then I went into the modem and put the Orbi into DMZ+ mode (bridge mode). No issues so far.
ukwildcat4life
Jan 17, 2017Star
+1 juniormint88 I just configured the same setup with my Orbi system....put the AT&T gateway(5268ac) into passthrough mode using DMZ+ and didn't have an issues at all regarding a decrease in speed, etc......
- jrmurfJan 18, 2017Initiate
thank you all, I will try everything you suggested
I really appreciate the help!
