Tempo36
Dec 03, 2019Aspirant
Setting up backhaul on an AP orbi
Hey folks, I have an RBR50 kit (RBK50) set up where the router is set for access point mode and the satellite is remote. We discovered an ethernet port hardwired into the house (go figure!) and so ...
Dec 03, 2019Guru - Experienced User
Should be setup and go.
Be aware of managed switches if one is is use or switches with "Green Ethernet" features. Can cause problems for Orbi with ethernet connected RBS.
