Piquard
Jul 22, 2020Aspirant
Setting Up iPv6 on Orbi50
I am with a ISP who provide a Static IP. They are moving us over tp IPv6 and have provided me with the IPv6 settings. I have the WAN IP6 Address, WAN IP6 Gateway , and the LAN IP6 Network address. H...
CrimpOn
Jul 22, 2020Guru - Experienced User
Piquard wrote:I am with a ISP who provide a Static IP. They are moving us over tp IPv6 and have provided me with the IPv6 settings. I have the WAN IP6 Address, WAN IP6 Gateway , and the LAN IP6 Network address.
How do I go about setting up my Orbi RBR 50 router?
Thanks for the "heads up", as this may eventually happen to more (and more) of us. I am puzzled that the ISP does not offer to supply the IPv6 information using DHCP. Having a "static IP" means that it is assigned specifically to you and will not be changed unexpectedly. I do not see what would prevent the ISP from responding to a DHCP request with the information specific to your account.
How did you decide that "fixed" was the correct option to select? Page 87 in the Orbi User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Piquard
hi Crimp on, thanks for responding, just for your info I live in Australia where we have a National Broad Band Network and my case I have Fibre to the Home which provides very fast speeds.
I used the " Fixed " setting as I assumed that as I have a Static iPv6 address that would be the appropriate setting??
- CrimpOnJul 22, 2020Guru - Experienced User
Piquard wrote:hi Crimp on, thanks for responding, just for your info I live in Australia where we have a National Broad Band Network and my case I have Fibre to the Home which provides very fast speeds.
Reading the Orbi User Manual about IPv6 makes me dizzy. I would probably call the ISP (who gave me the IPv6 iinformation) and ask, "how the heck do I set up my router with this? Can't I just keep using DHCP and have your network send me the settings when I ask for them?"
