kpaxnet
Apr 02, 2020Aspirant
Setting up Nighthawk R7000 as repeater to Orbi AC2200
Hello, I recently upgraded to OrbiAC2200 (1+1) from my older Nighthawk R7000. I am trying to setup my R7000 as a repeater to the Orbi. I understand that I need to do the following R700...
CrimpOn
Apr 02, 2020Guru - Experienced User
I understand that I need to do the followingR7000
1. Repeater Mode
2. Disable Security/Encryption
3. Enter the MAC address of the Basestation (i.e Orbi router)
4. Set the IPAddress to 192.168.1.1
5. Select the channel to some x (making sure that Orbi is also transmitting on the same channel)
AC2200
1. Set a fixed channel instead
2. From what i could reseach online. there is also a requirement to set Orbi as a Bridge?
though am not entirely sure of this part.
It would probably help if you can explain more about the end result being sought. i.e. in a general description in words rather than a "mode name". "I want to put the R7000 in (this part) of the house, connect it to the Orbi using (WiFi? ethernet cable?) and have devices in that part of the house (do what?)"
The Nighthawk R7000 User Guide explains how to set up an R7000 in three alternate modes starting on page 83. Bridge mode and repeater mode require an ethernet connection between the R7000 and the Orbi. Access Point mode does not.
Orbi cannot be set up as a "bridge" No way. No how.
kpaxnet
Ahh.. good point.
Essentially I am trying to increase the range of my Orbi router.
While I do have one satillite, which does increase the WiFi range quite a bit.
I still have a major dead zone right outside the garrage door (where I spend an inordinate amount of my time with my laptop working and yelling at the kids (aka multitasking) thx to covid -19.)
I would thus like to setup the R7000 as a repeater in the garrage,
so that I can get a better signal in and outside the garrage and work while watch the kids too.
