Citykitty21
Jun 27, 2022Aspirant
Setting up Orbi satellite system?
Not a tech novice, but...Just purchased the Orbi satellite system R10. On setup, I am instructed to plug in the Ethernet, then the internet cord into my cable modem, but I don't have a cable modem. ...
Jun 27, 2022Guru - Experienced User
What brand and model modem or ONT do you have? Or is there just a Wall jack where you plug in a router?
R10 isn't a model. Do you have a RBK10 series?
Citykitty21
Orbi RBK10. I have an Ethernet cord coming by from the wall (wire) installed by my provider. No other modem or anything else.
- CrimpOnJun 27, 2022Guru - Experienced User
That Ethernet cable coming from the wall goes into the "Internet" jack on the back of the RBR10 router:
- Citykitty21Jun 28, 2022Aspirant
Thank you for that clarification. I will try that!
