Jaonsdheurason's avatar
Jan 03, 2020
Setting up the network map
I have an RBR50 router supporting 2 satelites, 1 RBS50 and 1 RBS20. As I understand it, the RBS20 cannot support daisy-chaining to the RBS50; and this is evidenced by the problem I am having... The t...
  • tomschmidt's avatar
    Jan 03, 2020
    Login to your RBR50 router web interface and click on the Advanced tab. Expand the "Advanced Setup" and click on "Wireless Settings".  You can then uncheck the box for "Enable Daisy-Chain Topology" and click the "Apply" button to disable it.  The router and satellites may reboot when you change this setting.
