conker89
Sep 28, 2020Aspirant
Setting up the Orbi (again) but on a new broadband router/supplier
HI Everyone Hoping someone can assist or point me in the right direction. I have the RBS50 and 2 satellites, which I set up a while ago in my old house with assistance from someone on here and th...
Mstrbig
Sep 28, 2020Master
conker89 wrote:Thanks, I've followed most of this and the Orbi network is now setup, apparently running parallel to the original BT network. The issue I am having now is when I try to login to orbilogin.com as you suggested, it's not letting me, suggesting that it's not secure. I keep trying various password combinations that it would likely be, plus the apparent default of 'password' but no joy. This was the part of the process thatdid concern me the most as I don't want a clash between networks, the only available network should be the new Orbi network. Any suggestions?
When logging into orbi;ogin.com it always shows insecure network. The username is admin and the password is the password you chose when you set it up.
conker89
Thanks for you assistance so far, been very helpful. I've managed to reset the password to grant access to the login and have changed the Orbi router to AP mode within the advanced settings. Am I right in thinking that this is now the Orbi setup as far as a network and if so, do I now need to attempt to change the BT router so that it is not putting out a conflicting wifi network?
