donawalt
Feb 12, 2022Hero - Experienced User
Setting up wired backhaul
HI all, I am taking another stab at getting the RBR/RBSS850 set up in an old big house with lost of thick walls etc.! This time, I have been getting all the rooms wired with Ethernet, done! My curre...
- Feb 25, 2022
donawalt wrote:
Hi, as promised I am checking back with results! Everything worked fine, the network is running great! We have a rowhouse, about 4500 square feet with 3 floors and a basement. We have Comcast 1.2/40 service. I have an RBR850 in the basement where the cable comes in (somewhat in the center, thanks to a long cable), an RBS850 in the dining room on the first floor roughly 1/3 of the way in from the back of the house, nothing on the second floor, and another RBS850 on the third floor roughly 1/3 the way in frm the front of the house! All are well more than 30' from each other. I was very careful studying signal strength as I added the devices one at a time, as a result I only need two satellites, and the speed test results are great everywhere! The router handles the basement and 1st fl. living room at the front of the house, the RBS in the 1st fl. dining room near the back handles that room and the bedrooms on the 2nd floor right above it, and third floor RBS handles that floor (it's smaller than the other two floors) and the 2nd floor bedroom in the front of the house. Since I have about 24 Ethernet runs to different rooms, not only are the 2 RBSs wired for backhaul, but our 2 laptops, and 2 Apple TVs are wired. The rest of the Ethernet runs are not needed for now.
I turned on LAG as I have a CM1200 modem. I don't think I made any other changes to the default settings for the network, but I do want to ask for advice on some settings. I did not turn on Guest Network, Access Control, Netgear Security/Armor, or VPN; the router also serves as DHCP. Firmware is up to date 4.6.3.16. I am using the default Comcast DNS servers. IPv6 is on and working.
1. 2.4 GHZ is set to Auto, 5 GHz is set to channel 48. I assume that's ok, I have checked signals from other nearby networks and it looks reasonable. OK? Yes if it's all working. I prefer to use manual channels 1 and 40 or 11 and 48. I have a next door neighbor that has a Orbi system and there on 6 and 44.
2. Security is WPA2-PSK. I seem to remember I need to keep it there for my printers to work (HP Laserjet and an OfficeJet photo printer), as they have minimal security? Or should I do stronger security? Yes keep WPA2 for now. Mixed mode WPA2/3 we have asked about.
3. AX features are enabled on both 2.4 and 5 GHz. OK? Yes.
4. UPnP is on. I seem to remember that's only for games, if so, we don't need it for games, so should I turn it off? If you don't see any problems, you can leave it ON. It's not only for games.
5. 20/40 MHz Coexistance is on for 2.4 GHz. I seem to remember some issues with that, is it ok to leave on? If all of your devices are working well, leave it. Or you can set 40Mhz only.
6. WMM is on for both 2.4 and 5 GHz, is that correct? Yes.
7. CTS/RTS Threshhold is 64 for both 2.4 and 5 GH. Is that correct? Yes. Keeps this unless you see problems, then you can try 500 or 2347.
donawalt
Thank you all, very helpful! I'll post back how it goes!
donawalt
Feb 25, 2022Hero - Experienced User
Thank you in advance for your advice!
- donawaltFeb 25, 2022Hero - Experienced User
I forgot to add #7, RTS/CTS Threshholds are both 64. Should I bump them up to 2347?
- FURRYe38Feb 25, 2022Guru - Experienced User
Thanks you FURRYe38 for the replies and that thread. Whew! RTC/CTS is mind-boggling. I rtired a test this morning, with everyone out of the house, I had 3 simultaneous speed tests (3 different computers/devices) going plus watching for collisions, with RTS/CTS set to 500. No Collisions. I am wondering if that is a nice middle ground between the 64 and the 2347...
Give that a whirl and see. I've been using default 64 since v.5 version of FW came out and its been stable. Even with ethernet connected RBS. Were hoping that NG is moving in the right direction in regards to FW.
