hawk47
Sep 27, 2019Aspirant
Setup with Centurylink
I recently switched to Centurylink and I am trying to setup my Orbi router and satalites but each time I get to the part where it tells me to go to wifi settings and select the Orbi network I can't b...
hawk47
I have not used it with centurylink. I use to have Xfinity but just switched today to centurylink
CrimpOn
Sep 27, 2019Guru - Experienced User
Was it set up and working with the Xfiinity, or is this a new Orbi that you are setting up for the first time?
- hawk47Sep 27, 2019Aspirant
It was setup and working perfectly with Xfinity. When I am trying to set it up there is a point where you are suppose to select the Orbi wifi under network settings but the network name Orbi does not display.
