hawk47
Sep 27, 2019Aspirant
Setup with Centurylink
I recently switched to Centurylink and I am trying to setup my Orbi router and satalites but each time I get to the part where it tells me to go to wifi settings and select the Orbi network I can't b...
CrimpOn
Sep 27, 2019Guru - Experienced User
If it turns out that you have "a problem", it will be useful to know exactly which Xfinity and CenturyLink products are involved.
Some products are "only a modem" (which Orbi works best with). Some are a "modem/router". And, some are combiniation "modem/router/WiFi". They have different ways of assigning a network (IP) address to the Orbi.
I do not expect a "problem", but if you do run into anything, there are really smart people on this forum who have "seen it before."
