sonicspriter202
Jul 03, 2021Aspirant
Severe Packet Loss on Orbi RBR50
To whom this may concern, I have purchased my Orbi RBR50 last year at a local BestBuy, since I needed a stable Wi-Fi extension that can extend my connection due to my router being at the opposite...
- Jul 06, 2021
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What are you testing with to check packet loss?
I'd turn OFF all RBS and all wired and wireless devices and test with just one wired PC connected at the ISP modem and check packet loss here first using pingplotter.com. Then test with the RBR in the middle.
RookA
Aug 06, 2021Aspirant
FW - V2.7.3.22 for both Router and Satellite.
Modem - Arris BGW210-700
I have been using pingplotter to check packet loss once I noticed it occuring.
I tested with my pc wired to just the modem and no other devices on the network for about an hour and ping stayed under 30ms with <1% PL. I then connected the RBR to the modem and hardwired the pc to the RBR and again experienced no higher than 30ms ping with <1% PL.
Then I added the satellite back into the mix. It is 1 floor directly above my modem and router and gave a blue ring following syncing. (It still shows a "config sync" status in orbilogin.net). However, I disabled my WLAN card in my pc and hardwired to the satellite to ensure no interference. I saw roughly 5-7 ping spikes a minute at hop 1 carried through to the destination up to ~2900ms. PL% was around 28% for the duration.
Aug 06, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If your not seeing a GOOD status and only Config Sync, then the RBS is not fully syncing correctly. You'll need to remove the prior RBS connection from the RBR, apply the setting there. Factory reset the RBS and then attempt to re-sync it. IF this fails, you'll need to factory reset the RBR and RBS and setup from scratch.
