bmjelken
Nov 30, 2019Aspirant
Sharing wifi from home to shop
I have fiber internet to my home. I also run a business out of my home. I need to get internet into my new shop behind the house. I am going to say the new shop is 100+ feet from the house. The nighthawk is currently on the opposite side of the house from the shop. Unfortunately the router location can not be moved.
The new shop is a metal building with wood studs. The current wifi signal does not reach the shop. I do not have any network extenders or boosters in the home. What product would you recommend to use to get signal to the new shop?
Thank you for any assistance, let me know if you need more info and what info you would need.
- PixarAspirant
I run 2 outdoor Orbi's and the last one is inside a metal building.
works great. first out door is on the main house as I have the same problem.
Orbi router reach that then the next out door connects to the other outdoor orbi !
Works great !
Good Luck !
- PixarAspirant
Also , I now have 7 sats running at the same time. ( off one Orbi 50 router )
