Sweetmo
Dec 22, 2020Tutor
Shark Robot IQ won't stay connected to Wifi
I've scoured the internet and forums for several days and can't find a specific match on this scenario. Upfront, I am pretty sure I know what the problem is, but I don't understand why it gets the...
Dec 22, 2020Guru - Experienced User
something to try?
If you have an old router sitting around (even a wireless g/n one, the shart doesn't transmit much data), connect it and run it in AP (access point) mode. Just put the AP on a different ssid/wireless so it doesn't interfere with the orbi.
See if the shark stays connected.
maybe its the shark, maybe it has an issue with roaming between satellites.
Or even try shutting off the satellites during a period where its running and see if its an issue when its not roaming between router/satellites.
